Linking Elbows Supports to OpenPlant Physical Catalogue
Hi All,
I've been modifying supports so they are spec driven in the schema, in most cases everything works.
The only supports so far that I can't get to work are Elbow type supports - Adjustable Elbow Support, Dummy Leg Support.
First are these able to be spec driven?  If so is there a wiki that shows the steps involved with linking the spec to these support types?
Ray
