Dummy Lag Support - Origin Location
When a Dummy Leg Support is placed on a pipe, the origin of the support is some random number away from the actual origin of where it should be.
How is OPM calculating the origin of the support and what is this point that the support starts at?
And no its not the intersection point of the centre of the support and the edge of the pipe, there is a gap.
Ray
  • Hello Ray Lucas,
    Have you tried to use OpenPlant Support Engineering for support placement? I believe you won't get this problem with it. Regarding your situation in OpenPlant Modeler, I would like to inform you, that this is a known situation and we have a Enhancement request already filled.
    Please create a Service Request and I will assign it to this Enhancement Request. I will try to contact our development team and I will update you directly.
    Best Regards,
    Kestutis Mitkus
    Best Regards,
    Kestutis Mitkus
    Application Engineer, Building, Structural & Plant
Reply
  • Hello Ray Lucas,
    Best Regards,
    Kestutis Mitkus
    Best Regards,
    Kestutis Mitkus
