Intelligent Line Manager Default settings
I am experimenting with the Intelligent Line Manager command in both SS5 and SS6.
The command always opens with the corner option as Pipe Bend, which is not what our industry would most commonly use. We have to select Standard Elbow, then select Long Radius every time we use the command.
Is there a way to set the default for this command a different way? Specifically for standard elbows and long radius so we don't have to have our users change it every time. The standard elbow and long radius are the default for the Join Components command.
Our tech says it looks for a Class and uses Pipe Bend as the default but doesn't know why it chooses that one or how to change it.
