The piping model I was updating unexpectedly received errors when launching AutoPlant. I was using AutoPlant without any issues one minute, closed down the model to rerun the Navisworks file and re-entered to continue working whereby at this point I received the following error:
My previous session of AutoPlant successfully saved and closed down without any known issues. No error warnings etc.
If I say no to the above dialogue box then I receive the following messages:
Finally, if I try to continue working in AutoPlant and try to make and changes, add anything new, then this eventually causes the model file to crash upon receiving this final warning message:
I so far have attempted to use the ‘back-up’ model file from a period prior to receiving these problems yet this for some reason still prompts the same issues. As it stands I am unable to make any design progress with this model file in particular. FYI, a colleague of mine is working on a different model file and has not received any errors in his area, yet does receive the same errors that I experience if he attempts to open up my file. It seems the errors are confined to the model file rather than user/PC.
Any assistance which could help resolve these errors would be greatly appreciated.
Phil Wheatley.
Hello David,
Thanks for posting your query to Plant forum!
Can you please recheck the images you have attached here? It is not visible at our side.
Also Please mention Product version details to enable us to help you easily.
-Regards | Rahul Kumar
PS- Please include tags while posting any query to forum
Rahul Kumar
AutoPlant v8i ss4 version 08.11.09.140
Thanks!!
Phil.
