How do I set the continuation label going between sheet 1 to sheet 2 of a pipeline to show the full linenumber + sheetnumber.
I would have thought using the $(LINENO)-$(SHEETNO) in the configuration dialog would work, but that's not the case.
Best regards,
Tuan Le
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Hello Tuan,
Isometric output format is 'DWG' thats why you were not able to see tag data and its showing blank.
Try to change isometric generation format to 'DGN'. and generate isometric you will see the drawing data.
Hope this help. Looking forward to your reply.
Abhijit Bute
Tuan,
Regarding TEXTNODES, please explain with some sample or screenshot what you want to achieve. If I understood you correctly, you want to have these TEXTNODES as separate TAGs posted in generated Isometrics model? Some of them by default always are posted in generated Isometrics.
You can find good information about how to work with TEXTNODES in Help Contents and in this wiki:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/12638.modifying-text-and-annotation-settings
Regards,Kestutis M.
Answer Verified By: Tuan Le
