In AutoPLANT SS8, I'm not sure about previous versions, the list of Specs in the Component Preferences dialog show the specs in an order based on, I'm not sure what.
RebisPrefSelect.ListSpecs (always funny to see Rebis still hanging around the software)
Can this order be modified to say A-Z order?
Ray
Hello Ray,
I am checking with default project, and I can see the spec are order from A to z.
Are you getting different result? Please share the screen shot so that it will help us to understand your issue more clearly.
Looking forward to you reply.
Abhijit Bute
Sure,
I've tested a few things and I can't work out why its showing them in a different order.
The specs are a mix of Access 2000 and 2003
If I point the Metric default project to my set of specs on a network drive, this is the list I get.
Was there a resolution for this? Please update your findings. Thank you.
