OPIM User Labels - Number how to add padding
In OPIM, a User Label requires to have Number as part of the Text, this required to be 3 digits long, example 003, 023, 230
The issue is if there is a leading 0's they are dropped when the ISO is produced, (3, 23, 230), I'm not sure where this is being done, but how can I force it to have leading 0's or padding for the Number field.
Example below
Name - Instrument Label
Include - EC_Class=Relief_Valve|Gauge|Flow_Meter
Exclude - EC_Class=Flow_Orifice_Plate
Text - $(DEVICE_TYPE_CODE)$$(SYSTEM)$(NUMBER)
Type- TAG
Cell Name - INSBUB
Flags -
Ray
  • Hello Ray,
    I have reproduced your situation with Older OpenPlant Isometric Manager version and found a Defect Report 157233, which is already fixed in our latest OpenPlant Isometric manager SS6 version. I would recommend you to upgrade OpenPlant Isometrics Manager version and you will have NUMBER with leading zeros in generated Isometrics model same as in OpenPlant or AutoPLANT.
    As well I have found a possible solution for this situation and detail workaround posted in our Bentley Communities:
    http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/18489.how-to-modify-valve-tag
    Please let me know if you have any further questions or mark this thread as answered if this suggestion will help you with your requirement.
    Kestutis Mitkus.
    Best Regards,
    Kestutis Mitkus
    Application Engineer, Building, Structural & Plant
    Answer Verified By: Ray Lucas
