OPPID, Custom Border with new properties
Using OPPID SS6, i'm trying to create a new border with new document properties. I followed the procedure How to Add Custom Border in OPPID
But I can't see the new document properties, Border works fine, it can be added but I can't get the new properties in OPPID Drawing settings.
Does the procedure changed for OPPID SS6 version?
SH
  • Harpreet,
    I followed the procedure but at step 22, I can’t find the "Property Priority" custom attribute. Schema structure (1.07) seems to be changed in SS6 release.
    I don’t see DOCUMENT_PID but only Document in OpenPlant_ProjectProperties.01.07
    SH
  • Hello SH,
    The OpenPlant_ProjectProperties schema was used in the past and can still be used today, however, I recommend you add the properties to the OpenPlant PID schema. Add them under the PID_DOCUMENT class.
    Specific to the "Property Priority", this has changed and is no longer a separate custom attribute. The Property Priority is now set on the property name itself. See below.
    Also note that the Tag Set Tag Name MUST match the property name in the schema.
    I hope this helps,
    Tony DeRosa
    Bentley Plant
    Tony DeRosa
    Senior Application Engineer
    Bentley Plant
    Answer Verified By: S. Hotte
Reply
  • Hello SH,
    I hope this helps,
    Tony DeRosa
    Bentley Plant
    Tony DeRosa
    Bentley Plant
