I noticed in the download page that there is no OE that supports Autocad 2014, I went over all of them and there are versions for 2015, 2016, 2013 and older versions but 2014 and 2017 are missing.
Is there anyway to make these Objects Enabler load in Autocad 2014? I installed the last version available (for Autocad 2016) I tried to load them manually into Autocad 2014 but I am getting an ugly "is incompatible with this version of AutoCAD" message and refuses to load.
I would appreciate, any answer, thanks for all your help.
Hello Todd, thanks for your reply, as the title implies I do not need an Autodesk Object Enabler at all, it is the opposite, I need an Autoplant object enabler for Autocad 2014. In the download page of Bentley there is no OE compatible with Autocad 2014, there are for 2016, 2015, 2013 etc, 2017 is not available either.
Thanks for sharing the information.
Regards: autocad classes in delhi
