I am very confused about why I installed the Openplant V8i serise 5 after opening to show a series of errors, such as a photo
Hello J L,
In this error message program is informing, that OPM_PRYMARY_SCHEMA variable is defining wrong schema and OpenPlant could not establish connection.
Similar issue was discused in this forum thread:
http://communities.bentley.com/products/plant/design___engineering/f/5927/p/100423/340473#340473
Please open projects *.pcf file with any text editor and check which schema is defined in OPM_PRYMARY_SCHEMA variable. If it is set to use earlier schema version (01.04), than you should edit this variable.As well check, which schemas is used in your project. If version is older than 01.06, than you should upgrade them.
Please check provided suggestion and inform us here about your results.
Regards,Kestutis M.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Thanks for Posting your query.
Did you upgrade existing workspace? In addition to suggestion posted here, you can also check below wiki link. Also check step 12 mentioned there.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/28270.how-to-upgrade-schemas-from-old-version-to-latest-version-using-schema-upgrade-tool
Also check below wiki -
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/27044.startup-error-launching-openplant-modeler
HTH
-Regards | Rahul Kumar
Rahul Kumar
