Dimension tolerance for very small offset in vertical pipe
In OPIM build 08.11.09.572, in our model we have a vertical pipe with a very slight offset. It's 3 inches in the horizontal for 15 feet in the vertical. It comes out to less than 1 degree. The isometric shows the proper location for the pipe at the low point and farther along the piping at the high point, but does not indicate an offset or supply a dimension for the difference in location between the low and high point for the piping. This would cause installer to weld the piping incorrectly, thinking it was vertical.
I can't find a tolerance setting for dimensions to have it show an offset. Where can I find one or what can I change to make the offset dimensioned?
