I have a Project that I would like to use as a Custom Base Schematic Template for creating New Projects in Project Administrator. Currently I am only presented with two options, either "Standard Base Project" or "KKS". I would like to add my own based on an existing Project (on a network drive) as an option when creating New Projects.
I did this many years ago, but I can't remember how to do it.
Any assistance will be greatly appreciated.
Cheers,
Stephen
Hello Sephen,
To create a custom Base Schematic Template, simply go to the directory: C:\Program Files\Bentley\Plant V8i\Base\Options\ and either copy or create a new template.
A detail information about how to create and configure Projects in AutoPLANT is posted in this article:
http://communities.bentley.com/products/plant/design___engineering/b/plant_design_and_engineering_blog/archive/2010/06/07/creating-and-configuring-projects-in-autoplant-v8iPlease inform us about your results and verify answer if this will help you to achieve your requirement.Regards,Kestutis M.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
