Good Day,
When generating an isometric of a line continuing to another starting from a Tee, this tee is not shown with a dashed line.
When the line continues to an elbow, the elbow is shown dashed.
If the line continues to another pipe, the continuation also is shown correctly dashed.
This is how openplant isometric manager configuration page looks now:
What can I do to fix this issue?
Thanks a lot in advance!
Autoplant version: 8.11.11.135OPIM version: 08.11.09.458
Hi Joey,
Thanks for your reply.
Sure thing. Attached you fill find the .dwg generated
5466.TEST.dwg
Thanks in advance
Hi Joe, Sorry for the delay.
I have changed the setup to create a dgn file (instead of a dwg file) and the dgn file shows the dashed tee!
So something in the conversion is messign with it.
Here you will find the attached dgn file.
Looking forward to your response.
Best Regards
1680.TEST.dgn
Hello Luis,
Could you please try following steps:
For more details regarding Micro-station conversion to dwg line style refer following link:
http://communities.bentley.com/products/microstation/w/microstation__wiki/15269.saving-a-dgn-to-dwg-the-line-styles-are-not-displaying-correctly
Hope this help. Looking forward to your reply.
Regards,Abhijit Bute
Answer Verified By: Luis Barbiero
