When I copy Equipment or Piping Components, annotation does not copy with it unless I highlight the annotation too. If I highlight just the equipment and copy, the populated properties do not display. Is this WAD? or is do I have a schema/configuration problem?
Hi Neil,
I think you are using copy command which does not place tag annotations on copied components. You should use "Copy to Clipboard" command while copying and "Paste from Component Clipboard". Please refer below wiki article for more details.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/27508.workflow-to-copymove-components-from-one-drawing-to-another
Hope this helps!
Regards,Harpreet
Answer Verified By: Neil Norberg
