what is the perfect plan for water plant design and Municipal water supply and drainage design ?
I just contact OPM soon, and i want to know  what is the solution if i work on water plant design and Municipal water supply and drainage design? For example  design,and rendering, and so on.  what is the best  combination of software?
  • Hello,
    Thanks for your concern here. We are in discussion with team. We will update you shortly with the right combination.
    Could you please share your contact details so that we can contact you if any discussion required?
    -Regards | Rahul Kumar
    Rahul Kumar
    Product Engineer – Global Technical Support | Community Moderator
  • Hello Junjie Shi,
    To Make a precise decision for the same, I would like to request you to contact Account Manager from Bentley who can advice for best suited product which you could choose.
    For Water Plant Design / Municipal Water Supply, there might be various hydraulic simulations/calculations being used. The Haestad products such as StormCAD and WaterCAD can assist with hydraulic design of the water network and storm drain system. For example WaterCAD can simulate pressure, velocity, etc for certain pipe sizes, pumps, etc and StormCAD can tell the user if certain pipe and inlet sizes are adequate for certain design storms.
    For Design Activities and interoperabilities between WaterCAD and Plant products, a discussion with Account Manager is needed to arrange overall optimum solutions & guidelines.
    Hope this is fine with you.
    HTH
    Rahul Kumar
  • For Water Treatment Plant Design, we have a solution in place which should help you. I have attached a new brochure which outlines what we can do for you. Please do not hesitate to contact me for more information.
