Interface excel- Axsys process
Hello! I am writing here to know if you can help me with a doubt that I have about the use of AXSYS.Process software.
I am trying to use the interface between this program and Metsim. I understand that for this it is necessary to export an .xml file from excel with the data extracted from Metsim.
However, the AXSYS plug-in tab does not appear in my Excel. I modify the security of the Excel macros tool as I saw in an AXSYS user manual, and still it does not appear. And when it appears, I do not know the way to export well the data of currents and equipment. I would also like to know if it is possible to export another data sheet format so that the data is reordered in that way.
Thanks in advance!
