I have downloaded Object Enabler Select Series 8. I am having trouble getting the objects from AutoPLANT to come up on AutoCAD 2016. Is there anyone who can give a step by step on how to make those visible.
These are the files that were downloaded, need some assistance on what to do to get these into AutoCAD 2016
Blake
Hi Blake,
You can download correct Object Enabler for 2016 from below link. You need to login into Communities then you will be able to download it.
Regards,Rajesh Agrawal
http://communities.bentley.com/products/plant/design___engineering/m/plant_design_and_engineering_files/272439
Here is link to wiki article in which we will create links to download all latest AutoPLANT Modeler Object Enablers for AutoCAD:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/32642.autoplant-modeler-object-enabler-v8i-for-autocad
All installation packages are compressed and they contain simple setup.exe file for Object Enabler installation
Hope this information will help.
RegardsKestutis M.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
