I hope what I am about outline is not too convoluted or confusing. However, here goes.
I customized the OpenPLANT_3D.01.04.eschema.xml (SS7) with great success. With the new version OpenPLANT_3D.01.07.eschema.xml (SS8) not so much success.
I know and accept that improvements have been made and needed, but I am at a loss as to what I am doing wrong.
I am using the same steps in the new version as I did in the old version, as follows:
As I stated above as far as I can remember these are the steps I used (although it has been 12 months since I did this) in the old version.
However, I cannot get the new Property to appear/display in AutoPLANT's Component Preferences. I need to be able to do this to fully populate the Isometric sheet titleblock textnodes for full automation.
I did a comparison between OpenPLANT_3D.01.04.eschema.xml and OpenPLANT_3D.01.07.eschema.xml and found subtle differences. See attached images.
Am I doing something wrong? Have I missed a step? What else do I need to do?
Cheers,
Steve
Stephen Wood-Davies
Senior Designer / Bentley CAD Administrator
