why couldnot placing a angle valve,there are just gate valve and ball valve that could be used,As picture.
JL
Hello JL,
Answer to your question is posted in this Bentley Communities wiki article:http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/31917.no-component-found-with-initial-selection-from-specs-appears-while-placing-component
I hope this information will be useful. Please let me know if you need additional help on this topic or if you have other concerns/questions.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Hello J L,
With above suggestion guided by Kestutis, you can also check below wiki article to see if some table missing in schema.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/22009.how-to-map-spec-table-for-placement-of-missing-component
HTH
-Regards | Rahul Kumar
Rahul Kumar
