Can't get Object Enablers to work in AutoCAD 2013
I'm trying to get the object enablers to work for AutoCAD 2013 in Win7 E. I have a user who has both AutoCAD 2012 and AutoCAD 2013 (due to version specific vertical addons.) The Object enablers seems to load perfectly fine into 2012. I can't even actually uninstall them from Programs & Features.. The Asset intelligence object goes away, but they actually seem to stay installed and loaded in 2012. But I cannot seem to make them work in 2013. I've tried adding the same 5 support paths as shown in 2012, but it doesn't seem to work with just that. Is there perhaps a configuration file I must also modify?
The DWGs we're trying to open in 2013 still give us AT_Reboids errors, showing ref blocks for the elbows in the drawing, where in 2012 it all shows up perfectly fine.
I've tried apoe081109140en.exe, apoe08111226en.exe, apoe081113129en.exe, & apoe081113211en per several of the other posts here, but no luck.
