When I tried to start OPIM SS6 from command line, I've got the following error.
I've tried to run with a elevated cmd session as well and same error occurs. Any particular reason why that is the case?
Best regards,
Tuan Le
Thanks very much Kestutis. Change the current directory does the trick. Any chance I can request this quirk removed? We usually use our in house interface to launch bentley software, and now Isometric Manager has to be treated differently from the rest. And that's not ideal.
Best regards, Tuan
Is it possible to do similar in vbscript? I use hta files to a similar effect.
I would say you should be able to, Bear. Can't see why not.
