Need recommendations on using OpenPlant PID using DWG file format
Hello All,
In order to avoid a conversion from DGN to DWG at the end of the project, we would like to use OPPID with DWG files. So far, it's not going so bad:
  • We can work as if the files were DGNs
  • The drawings can be synchronized to the database
  • They can be opened in AutoCAD
We're having issues with
  • Line styles. Instrument lines, which are mostly custom line style, can be placed and are showing properly when they are placed but as soon as we reopen the file, they appear as solid lines.
  • The colour table is the AutoCAD one and cannot be changed.
My questions are
  • Has anybody tried that before? What are you recommendations?
  • What is Bentley's recommendations?
  • Should we forget about that option and just deal with the conversion at the end?
Best regards
Alain
