In raceway I would like to change Air Gap to show as 'Free Air'. I have found this text in SPEC_AutoRouter.xml but I am not sure if this is the only place this would need to be changed or if this changes is even possible. I would also like this to show up this way in reports. Please advise if this can be done on files that would need to be changed.
Hi Eric. The file you want is actually CAT_Virtual_Connection_Descr_EN.xml. You will want to change the
<Naming PartDescription="Virtual Connection" ExtDescription="Virtual Connection" />
line to
<Naming PartDescription="Free air" ExtDescription="Free Air" />
Its shows when naming a segment of raceway and this ID also shows in Reports.
