User defined valves do not seem to show Insulation. Are we missing something?
Hello Peter,
Are you getting some error?
-Regards | Rahul Kumar
Rahul Kumar
For custom components, graphical update is not supported. However you may feed the information in property regarding insulation to to be extracted as reports. Alternatively, you can also include insulation thickness while creating custom component and make the whole component including insulation by default. But this way you have to create separate custom component with various insulation thicknesses.
HTH
