OPIM V8i SS6 (v08.11.11.224)
AutoPLANT Modeler V8i SS8 (v08.11.13.211)
Need a dash to be inserted in my dimesions so that they read 1'-10 3/8"
In the Dimension style, I have tried to set it to MU label - SU label with the units set to feet and inches (which should include a dash between master units and sub units), but I still get no dash. Is there another way to make this work?
Here are my settings:
Thanks in advance.
Jesse Wolfe
Hello Jesse,
You can also give try using Style.cfg file. There are many options present. Please have a look below.
HTH
-Regards | Rahul Kumar
Rahul Kumar
Answer Verified By: jwolfe
