Autoplant Reinforcing Pad not shown in bill of materials of isometric generated with opentplant isometrics manager
Good ay,
Reinforcing pads are not listed in the bill of materials of the isometric.
Please notice that the reinforcing pad symbol is shown (as seen below)
Versions in use:
Autoplant version: 8.11.11.135 (series 6)
OPIM version: 08.11.11.224
Schema version: 01.04
Thanks a lot in advance!
  • Hello Luis,
    Using this wiki article check which EC_CLASS or IE_TYPE values has this component.
    Then using this wiki article include component's EC_CLASS or IE_TYPE in your report.def file and test your isometrics again.
    This way you should see required component in generated isometrics Bill Of Material list.
    Please update us about your results.
    Kestutis M.
    Best Regards,
    Kestutis Mitkus
    Application Engineer, Building, Structural & Plant
  • Hi Kestutis, thanks for your reply.
    I'm sorry, but can you please check the first wiki article suggested? It doesn't say anything regarding how to get the EC_CLASS or the IE_TYPE.
    Looking forward to your response.
    Thanks in advance.
  • Hi Luis,
    Sorry, I haven't wrote you to check the screenshots in eighth step.
    1. Generate Isometrics model
    2. Select IsoExctractor>Show Tag Data nad then select Show Components Tag.
    3. Click on your Reinforcing Pad symbol and then Components Tag data dialog will open.
    You can use any property from this dialog and have this data in your Bill Of Material. Hope this information will be useful.
    Please inform us here about your rersults.
    Kestutis M.
    Best Regards,
    Kestutis Mitkus
  • Thanks Kestutis,
    Checking the component tag of what I tought was the reinforcing pad, I realize that the simbol refers to "CT_OLET" which is the pipe to pipe connection.
    What I'm trying to do is to have a reinforcement pad like this one:
    To appear in the isometric bill of materials.
    This is the element info that appears when I double click on the reinforcement pad:
    This is the reinforcement pad data when I use Piping/View Database (the element is the AT_REPAD):
    This is the intermediate file (no AT_REPAD) is there:
    #Intermediate[L00] file
    #Copyright © 2016 Bentley Systems, Incorporated. All Rights Reserved
    #Version:08.11.11.224
    COMP 1 PIPE PIPE0.5CSASME~B36.10M-2004XS
      ATTR NA PIPE HA2 TEST3 0 -1 1
      0 0.5 0.5 0
      2 1
      0
            0 1 0 BW
            0 -1 0 PE
            0 0 0
    COMP 2 WELD WELD
      ATTR NA WW NOSPEC TEST3 0 -1 1
      0 24 24 0
      2 3
      0
            0 -1 0 BW
            0 1 0 BW
            0 0 0
    COMP 3 OLET_8 TAG
      ATTR NA RBRBW3 NOSPEC TEST3 0 -1 90
      0 12 24 0
      3 4
      0
            0 -1 0 BW
            0 1 0 TAP
            0 0 0
    COMP 4 PIPE PIPE24CSASME~B36.10M-200460
      ATTR NA PIPE DA1 TEST3 0 -1 1
      0 24 24 0
      5 8
      0
            -1 0 0 BW
            1 0 0 BW
            0 0 0
    TAPNODES 4
    COMP 5 WELD WELD
      0 24 24 0
      5 6
      0
            1 0 0 BW
            -1 0 0 BW
            0 0 0
    COMP 6 FLANGE_4 WELD_NECK_FLANGE2424ASME~B16.5-2003CSCL600
      ATTR NA FLNWNF DA1 TEST3 0 -1 51
      0 24 24 0
      7 6
      0
            -1 0 0 FL
            1 0 0 BW
            0 0 0
    COMP 7 WELD WELD
      0 24 24 0
      9 8
      0
            1 0 0 BW
            -1 0 0 BW
            0 0 0
    COMP 8 FLANGE_4 WELD_NECK_FLANGE2424ASME~B16.5-2003CSCL600
      0 24 24 0
      10 9
      0
            1 0 0 FL
            -1 0 0 BW
            0 0 0
    NODES
        1 2347195.628507 1190169.91832 0
        2 2347195.628507 1289741.929763 0
        3 2347195.628507 1289741.929763 0
        4 2347195.628507 1289741.929763 0
        5 2097195.628507 1320203.255042 0
        6 2097195.628507 1320203.255042 0
        7 2076240.628507 1320203.255042 0
        8 2597195.628507 1320203.255042 0
        9 2597195.628507 1320203.255042 0
        10 2618150.628507 1320203.255042 0
    END
    UNITS  IN MM
    LABELING
    END
    TEXTNODES
      FILENAME        TEST3
      STYLE        As-Built
      DATE        24/03/2017
      TIME        14:42:31.8236147
      PRJ_NAME        I1349_02
      SIZE1        24"
      SIZE2        12"
      SPECMAIN        DA1
      SPECSEC        HA2
      INSTANCE_ID        ISOSHEET::TEST3
      STORAGE_PATH        Isometrics\
      STORAGE_ROOT        Isometrics
      LINENUMBER        TEST3
      UNIT        U100
      SERVICE        P
      NAME        TEST3
      ACTIVE        True
      SHEETNO        1
      NO_SHEETS        1
      PRESPLIT_SHEETNO        1
      PRESPLIT_NO_SHEETS        1
      REPOSITORY_IDENTIFIER        U:\I1349 PLANTA COMPRESORA ULE\3D_Project\I1349_02\config\OpenPlant\ecxml\b97b603c-f2d7-489b-ac0b-ec52fb6226c0\I1349_02_1490380881
    END
    BOMLABELS
      8  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=WN Flange,CL600, RF, ASTM A105,ASME B16.5, SCH 60, (125 - 250 Minch);IE_SPEC=DA1;IE_TYPE=CT_FLANGE;IE_ITEMCODE=WELD_NECK_FLANGE2424ASME~B16.5-2003CSCL600;IE_SEQID=8;DIM1=209.55;SIZE1=24;CM1=FL;SIZE2=24;CM2=BW;UUID=AT_ITACPOWF_8V;COMP_STATE=DESIGN;EC_CLASS=WELD_NECK_FLANGE;STATE=DESIGN;RATING=CL600;LINENUMBER=TEST3;AREAID=03;INSULATION=AA;SPECIFICATION=DA1;SCHEDULE=60;NOMINAL_DIAMETER=24;UNIT_NUMBER=U100;STANDARD=ASME B16.5-2003;SHOP_FIELD=SHOP;SERVICE=P;TRACING=0;MATERIAL=CS;DRY_WEIGHT=398.46;DESCRIPTION=WN Flange,CL600, RF, ASTM A105,ASME B16.5, SCH 60, (125 - 250 Minch);GUID=AT_ITACPOWF_8V;PIECE_MARK=FLGWNK24;END_TO_END_LENGTH=209.55;DESIGN_THICKNESS_OF_FLANGED_END=107;OUTSIDE_DIAMETER_OF_FLANGED_END=939;INSULATION_THICKNESS=0;OUTSIDE_DIAMETER=609.6;TOTAL_WEIGHT=0;
      7  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=BUTT-WELD;IE_TYPE_EXT=SHOP;IE_TYPE=CT_WELD;IE_ITEMCODE=WELD;IE_SEQID=7;DIM1=0;SIZE1=24;CM1=;SIZE2=24;CM2=;UUID=AT_ITACPOWF_8W;COMP_STATE=DESIGN;EC_CLASS=BUTTWELD;STATE=DESIGN;P2_X=25971.95628507;P2_Y=13202.03255042;P2_Z=0;TYPE=SHOP;NOMINAL_DIAMETER=24;LINENUMBER=TEST3;DESCRIPTION=BUTT-WELD;P1_X=25971.95628507;P1_Y=13202.03255042;P1_Z=0;GUID=AT_ITACPOWF_8W;
      6  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=WN Flange,CL600, RF, ASTM A105,ASME B16.5, SCH 60, (125 - 250 Minch);IE_SPEC=DA1;IE_TYPE=CT_FLANGE;IE_ITEMCODE=WELD_NECK_FLANGE2424ASME~B16.5-2003CSCL600;IE_SEQID=6;DIM1=209.55;SIZE1=24;CM1=FL;SIZE2=24;CM2=BW;UUID=AT_ITACPOWF_8Q;COMP_STATE=DESIGN;EC_CLASS=WELD_NECK_FLANGE;STATE=DESIGN;RATING=CL600;LINENUMBER=TEST3;AREAID=03;INSULATION=AA;SPECIFICATION=DA1;SCHEDULE=60;NOMINAL_DIAMETER=24;UNIT_NUMBER=U100;STANDARD=ASME B16.5-2003;SHOP_FIELD=SHOP;SERVICE=P;TRACING=0;MATERIAL=CS;DRY_WEIGHT=398.46;DESCRIPTION=WN Flange,CL600, RF, ASTM A105,ASME B16.5, SCH 60, (125 - 250 Minch);GUID=AT_ITACPOWF_8Q;PIECE_MARK=FLGWNK24;END_TO_END_LENGTH=209.55;DESIGN_THICKNESS_OF_FLANGED_END=107;OUTSIDE_DIAMETER_OF_FLANGED_END=939;INSULATION_THICKNESS=0;OUTSIDE_DIAMETER=609.6;TOTAL_WEIGHT=0;
      5  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=BUTT-WELD;IE_TYPE_EXT=SHOP;IE_TYPE=CT_WELD;IE_ITEMCODE=WELD;IE_SEQID=5;DIM1=0;SIZE1=24;CM1=;SIZE2=24;CM2=;UUID=AT_ITACPOWF_8R;COMP_STATE=DESIGN;EC_CLASS=BUTTWELD;STATE=DESIGN;P2_X=20971.95628507;P2_Y=13202.03255042;P2_Z=0;TYPE=SHOP;NOMINAL_DIAMETER=24;LINENUMBER=TEST3;DESCRIPTION=BUTT-WELD;P1_X=20971.95628507;P1_Y=13202.03255042;P1_Z=0;GUID=AT_ITACPOWF_8R;
      4  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=Pipe, ASTM A106B, SMLS, SCH 60, BE, ASME B36.10M;IE_SPEC=DA1;IE_TYPE=CT_PIPE;IE_ITEMCODE=PIPE24CSASME~B36.10M-200460;IE_SEQID=4;DIM1=5000;SIZE1=24;CM1=BW;SIZE2=24;CM2=BW;UUID=AT_ITACPOWF_8G;COMP_STATE=DESIGN;EC_CLASS=PIPE;STATE=DESIGN;LINENUMBER=TEST3;AREAID=03;INSULATION_THICKNESS=0;SPECIFICATION=DA1;SCHEDULE=60;NOMINAL_DIAMETER=24;UNIT_NUMBER=U100;STANDARD=ASME B36.10M-2004;SERVICE=P;TRACING=0;MATERIAL=CS;DESCRIPTION=Pipe, ASTM A106B, SMLS, SCH 60, BE, ASME B36.10M;GUID=AT_ITACPOWF_8G;WEIGHT=1772.9;END_TO_END_LENGTH=5000;INSULATION=AA;LENGTH=5000;INSIDE_DIAMETER=560.4;OUTSIDE_DIAMETER=609.6;SHOP_FIELD=SHOP;DRY_WEIGHT=354.58;PIECE_MARK=PIP24;
      3  IE_FIELD_EXT=1;IE_EXISTING=0;IE_TAG=AT_ITACPOWF_8G.AT_APN_1;IE_DESCRIPT=SOLDADURA TUBO A TUBO;IE_ORIGINAL_DESCRIPT=RBR_SET_ON;IE_TYPE=CT_OLET;IE_ITEMCODE=TAG;IE_SEQID=3;DIM1=0;SIZE1=12;CM1=BW;SIZE2=24;CM2=TAP;UUID=AT_ITACPOWF_8G.AT_APN_1;EC_CLASS=TAP_CONNECTION;REFERENCE_POINT_Y=13202.03255042;REFERENCE_POINT_Z=0;REFERENCE_POINT_X=23471.95628507;BRANCH_CODE=RBR_SET_ON;NOMINAL_DIAMETER=12;GUID=AT_ITACPOWF_8G.AT_APN_1;NAME=AT_ITACPOWF_8G.AT_APN_1;
      2  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=REPAD-WELD;IE_TYPE_EXT=SHOP;IE_TYPE=CT_WELD;IE_ITEMCODE=WELD;IE_SEQID=2;DIM1=0;SIZE1=24;CM1=;SIZE2=24;CM2=;UUID=AT_ITACPOWF_14E;COMP_STATE=DESIGN;EC_CLASS=BUTTWELD;STATE=DESIGN;P2_X=23471.95628507;P2_Y=12897.41929763;P2_Z=0;TYPE=SHOP;NOMINAL_DIAMETER=24;LINENUMBER=TEST3;DESCRIPTION=REPAD-WELD;P1_X=23471.95628507;P1_Y=12897.41929763;P1_Z=0;GUID=AT_ITACPOWF_14E;
      1  IE_FIELD_EXT=1;IE_EXISTING=0;IE_DESCRIPT=Pipe, ASTM A106B, SMLS, SCH XS, THRD, ASME B36.10M;IE_SPEC=HA2;IE_TYPE=CT_PIPE;IE_ITEMCODE=PIPE0.5CSASME~B36.10M-2004XS;IE_SEQID=1;DIM1=995.7201;SIZE1=0.5;CM1=;SIZE2=0.5;CM2=PE;UUID=AT_ITACPOWF_14C;COMP_STATE=DESIGN;EC_CLASS=PIPE;STATE=DESIGN;LINENUMBER=TEST3;AREAID=03;INSULATION_THICKNESS=0;SPECIFICATION=HA2;SCHEDULE=XS;NOMINAL_DIAMETER=0.5;UNIT_NUMBER=U100;STANDARD=ASME B36.10M-2004;SERVICE=P;TRACING=0;MATERIAL=CS;DESCRIPTION=Pipe, ASTM A106B, SMLS, SCH XS, THRD, ASME B36.10M;GUID=AT_ITACPOWF_14C;WEIGHT=1.613066585383;END_TO_END_LENGTH=995.7201144342;INSULATION=AA;LENGTH=995.5333672253;INSIDE_DIAMETER=13.88;OUTSIDE_DIAMETER=21.336;SHOP_FIELD=SHOP;DRY_WEIGHT=1.62;PIECE_MARK=TPIC1DAT0SC7000;
    END
    I went to the class editor and editer the Reinforcement  class, which already has AT_REPAD in attribute "AutoPLANT_PDW_Property_MAP".
    There I added the custom attributes: Isometric Mappings, Specific BOM Labels and Isometric Component:
    Can you please give me a hand on this?
  • Hello Luis,
    Please create Service Request regarding this issue, because I see that this might require more details and specific files. As well please attach sample model, which could help me to reproduce this situation.
    Kestutis M.
    Best Regards,
    Kestutis Mitkus
