We have a project that wants to make all piping of a system field material. This means that all welds are field welds and IsoManager dimensions the field welds.
We have turned off the Dimension Field Welds in IsoManager config and they have changed all welds in the system shop welds.
But the program still dimensions all the components individually. I assume that is because the entire system is set to field so all components are field.
Is there a setting or option to make field components not dimension individually so the isometrics with field components will dimension the same as the isometrics that are all shop components?
Hello Richard,
in style.cfg file are few variables which are forcing some components to be Field. Check 3 step screenshot in this wiki:
As well you can use overrides.txt file in styles config folder and override all field components to be not dimensioned:
Please add here few screenshots in which we could see your exact situation with notes what is wrong and what you want to achieve. We need more details about your requirement. Which source application for modeling you are using? AutoPLANT or OpenPlant?Thank you in advance and looking forward to hearing from you.
Regards,Kestutis M.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
