AP OPIM - Dimension discrepancy on socket fittings
Does anyone know how to set/fix dimension discrepancy on socket fittings?
For example, for 2" Tee or Elbow, each leg should be dimension as 38 mm, but currently it dimensioned one leg 38 mm and one leg 54 mm (16 mm of socket depth)
thanks,
Maggie
  • Hello Maggie,
    Can you please check with default spec for AutoPLANT Modeler & OpenPlant Isometrics Manager? Kindly mention Version details to allow us to check at our side.
    In case it is specific to project, then I would suggest to create a service request and upload all relevant data to test it and enable us to log it if it is appearing in default projects.
    -Regards | Rahul Kumar
    Rahul Kumar
    Product Engineer – Global Technical Support | Community Moderator
