I am looking for a software which have features:
3D model needs to be delivered with the drawing •
3 D model needs to be able to display the basic shape of the equipment .
• The proportions of the 3 D model shall be 1:1
• Shall be ISO 15926 compliant
• Shall be P&ID intelligent.
• Shall be clash free (soft-soft, soft-hard. Hard-hard)
• Shall be capable of generating P&IDs, piping material specifications (PMS) , mechanical and electrical equipment list , line list ,valves and specialties list , pipe supports list ,instrument list .piping BOQ, line wise and bulk MTOs ,pipe support MTOs, HVAC ducting and insulation MTOS
• shall be capable of generating 2D ACAD drawings like building GAs ,piping GAs & sections ,piping isometrics, cable layouts, HVAC ducting layouts ,HVAC ducting layouts ,instrumentation location layouts
• Tenderer should deliver the ISO 15926 XML output after due clash check and resolution at 30%,60%,90% and final stage .
• Shall accept structural building models from TEKLA (in IFC 2x3 format)/Creo/Revit ,if necessary .
• Shall permit exchange review and review of model over server .
• Intelligent civil details (even RCC rebar details ) to be transferred as ISO 15926 XML output.
• File format of 3 D model shall be parasolid .the file suffix is x_t ,or X-b .
Kindly suggest which software package can handle all the requirements stated above .
Thanks.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
