a water-mist sprinkler head is working in 10Mpa,connect with M18x10 thread
Hello Huang Yongbo,
Can you please provide some more background to understand your issue? From above query we understood that you need some custom component to add inside OpenPlant Modeler.
For creating custom component, you can check below wiki:
How to Create Multiport Custom Valve Applies To Product(s): OpenPlant Modeler Version(s): 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Component Subarea: Graphics… Last edited 2 months ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
For any query, please mention product version details inside tags field for more help
HTH
-Regards | Rahul Kumar
Rahul Kumar
Just wanted to follow up on your query here. Do you still have any concern?
yes,a sprinkler head seems not define like valve,cause it just one main port for water in,and how can i define a compression connect ?
Thanks for your response,
We would like to ask, on which class you need this Sprinkler to be created? Through customization one port custom component can be made & compression End can get assigned. But we need a class category for Sprinkler to define it inside schema.
Please provide some details here
i think a sprinkler can like floating valve or gauges have one port connect to pipes, it end with M18x1.0 male hread. it have two types,open type and close type with deferent k coefficient,when working in 10MPa k=1 means 10L/min.
