I'm using the the ISO name (IE_LINENAME) as part of the SPOOL number, the issue is I don't want to see the revision of the line name (.r001 / A)
Can I use a function in the User Label area to remove part of this attribute. EG =LEFT(IE_LINENAME,FIND("-",IE_LINENAME)-1)
Either that or is there a way to access the ISO sheet number? I could use it to build a label manually, but can't work out how to access the sheet number.
Currently
2T14-PIP-ISO-14150-01.r001-1
Require
2T14-PIP-ISO-14150-01-1
Ray
Hello Ray,
If you are generating Iso more than once, then automatically revision numbering is added to each new generated model. You can turn of this functionality and overwrite your isometrics with latest one without creating new revisions. Check this wiki article regarding this suggestion:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/17075/how-to-overwrite-revision-in-openplant-isometrics-manager
But if you would like to edit Iso sheet numbering format, then check this wiki:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/23069/how-to-format-number-property-in-isosheet-name
I hope this information will be useful. Please let me know if you need additional help on this topic or if you have other concerns/questions.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
