I was not able to get this to work, no matter what I set the Shop/Field to for a support it shows in the Field list.
When the Support tags are viewed in OPIM the IE_FIELD = 0, in the AutoPLANT model I have two supports, the Shop_FLD for one is set to 1 the other 2.
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/32588/how-to-show-support-components-under-field-or-shop-material-list-in-bom
Please help.
Ray
Hello Ray,
Thanks for your concern. we will check your concern we will get back to you soon.
Abhijit Bute
Not working for you either?
Any fix for this?
I was hoping it would be an easy fix
I have tested with out of box Metric project and seems working fine on my side.
Could you please check the same and let me know the result.
Looking forward to your reply.
Regards,Abhijit Bute
