OPIM AutoPLANT / OPM BOM changed with the newer version
With the newer version of OPIM, 08.11.11.224 the BOM format changed from a single mtext/textnode to individual pieces of text.
While this is good to control where the text is placed, it is hard to upgrade and then spend hours adjusting the report.def file to the new format.
What other options are there with the newer version to keep either single lines of text for each item or mtext/textnodes for the whole MTO?
Also I've found with the new BOM, the NODE in the drawing is not lining up with the exact location of the text, see the snapshot below, not sure what is happening here.
Parents Reply Children
