What would be correct approach to silent installation OPM SS6 on a clean computer box?
Best regards,
Tuan Le
Just wondering if there's any update on this one?
Tuan
Hello Tuan,
As I understood you achieved AutoPLANT Silent installation, but now you have issue with restart dialog during OpenPlant Modeler silent installation.If you are using any command for silent installation of OpenPlant Modeler, then you can add this ending of this command /qn/quiet/norestart. It will only work if it's put at the end. Note the sequence of the command - it should be the same as in the above example. It will not work if you shuffle the commands.
Hope this will help you, if no then maybe you could give us more information how are you installing silently? What command are you using?Regards,Kestutis M.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Hello Mr. Tuan,
I am trying to do something similar, can you please share the details of what exactly you did with HTA?
Hello Tuan Le,
If you need to upload any files, use below link.
Link to upload - https://bentley.sharefile.com/r-r77f1a0f5b36407fa
-Regards | Rahul Kumar
Rahul Kumar
I'll have to dig out the notes as all files was handed over to IT who looks after PC installation. But the idea was copying the implementation of "Autoinstall" switch in the Bentley Microstation Prerequisite pack to the Autoplant Prerequisite.
