I would like to import properties (ie. titleblock information) from old PDF isometrics into OPM. Is there a way to do this? I'm currently using SS5 OPM but would also like to have this information for SS6 OPM. Currently, we can extract the properties from the old isometric into excel. Ideally I would like to upload directly from excel but from the previous post on uploading pipeline properties, it seems that a text document is the only way to import into the DGN file.
Thank you.
Hi Kestius,
Please see the link below for importing Pipeline Instances.
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/8569/how-to-import-unit-service-pipeline-instances-from-a-text-file-to-an-active-dgn-file
I want to be able to import isosheet properties in a similar or better way. This would all be completed in OPM rather than in isometric manager. See attached image for an example of some of the properties that I would like to import.
PDF
Hi TMZ,
Please check below wiki section, which contains information how you can import your required data from Excel directly to OpenPlant Isometrics Manager using ODBC querying in textnodes.txt file.https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/18475/dbquery-usage-logging-debugging
Regards,Kestutis M.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
