We are able to connect to test environment with OPIM but when we connect to production datasource and click on start managed workspace , it throws below error message. any one has seen this before?
Hello Rakhi,
Can you try cleaning temp files. See below link for your help.
HTH
-Regards | Rahul Kumar
Rahul Kumar
Answer Verified By: Rakhi Bhargava
Hi Rahul,
thanks for the link and it fixed the problem. I did see this link but since error message was different was not sure if this will fix our issue.
Rakhi
