=> Does the Product Tree structure & nomenclature are maintained while converting to STP format in Open Plant Modeler? Is
1. Product Tree Structure is coming flat at level 1 after opening the converted file in other CAD software like Creo.
2. Product Tree Structure's node nomenclature has been modified.
=> Is the converted model a solid or surface extracted model?
All 3D geometries are surface type, for example only outer cylindrical surface is created for a pipe
Hello Jhhen,
Thanks for posting your query on Plant forum!
Currently this is not featured with OpenPlant Modeler. after conversion a solid/surface model gets extracted.
HTH,
-Regards | Rahul KumarProduct Engineer - Bentley SystemsAre you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Rahul Kumar
Answer Verified By: Jhhen Choudhary
Thanks Rahul for prompt reply!
Now, Help me with the situation:
I am having ".dgn" and "i.dgn" files. I have to use it for some other purpose on different platform like Creo / Navisworks. I wanna have product structure and its nomenclature intake while communicating via ".stp". What could be the possible solution. I am having Navigator software with me.
Thanks in anticipation ...
Hi Jhhen,
Can you please provide your contact details and email id so that we can take it offline?
Regards,Rajesh Agrawal
