I am getting an error trying to create an isometric directly from Openplant Modeler. The isometric does work when creating an imodel and using OPPID.
The error says "Path is not of a legal form"
Is there any information on how this can be resolved?
Does the OPIM dialog load and does it display when running from OPM like the following screen capture? If so what is the Isometric Style in use?
No, It begins to open it but I get the error before it opens.
I neglected to add that this is in a Projectwise file.
What is your project wise path set to in the Projectwise Settings?
Here Is my setting. It's defined in the schema.
