Hello All,
I found the only way to update OPPID pipeline label is to browse and select new pipeline tag, otherwise the existing old pipeline label won't update, and if place new label, the old tag number shows still. Is it a bug? For equipment, if I revise the area/service, the equipment label will be updated immediately.
Another problem, if I updated the piping tag, the piperun won't updated automaticlly. The piperun label is not same as pipeline label. Can it be fixed?
Thanks a lot!
Hello Mr. Changsong Ling.Thank you for informing us about your issue. This situation is a known issue and a Enhancement 334613 was already Filled with requirement to have possibility update all existing Tags, Annotations, Labels with changes done to component properties. At the moment we can suggest to delete old annotation and then place updated one manually.Best regardsKestutis Mitkus
Best Regards,Kestutis Mitkus
Product Engineer – Bentley Systems
I want to updated the tag numbers from existing P&IDs. I have updated EC expression in schemas and is working for new components. Is there any key-in that I can run in batch on all of the existing drawings to update tags from those drawings?
Vishal
Hi Vishal,
We will check with development team and get back to you shortly.
Harshavardhan K
Product Engineer I, Design Integration-Plant
