Hello All,
I found the only way to update OPPID pipeline label is to browse and select new pipeline tag, otherwise the existing old pipeline label won't update, and if place new label, the old tag number shows still. Is it a bug? For equipment, if I revise the area/service, the equipment label will be updated immediately.
Another problem, if I updated the piping tag, the piperun won't updated automaticlly. The piperun label is not same as pipeline label. Can it be fixed?
Thanks a lot!
Actually the new label will be old number still... The only way is to browse and select the pipeline number, then the labels will be updated automatically.
I want to updated the tag numbers from existing P&IDs. I have updated EC expression in schemas and is working for new components. Is there any key-in that I can run in batch on all of the existing drawings to update tags from those drawings?
Vishal
Hi Vishal,
We will check with development team and get back to you shortly.
Harshavardhan K
Product Engineer I, Facilities Engineering
