How can I disable the function Repairing Joints when I attach or refresh a reference.
Hi Michele,
Thanks for Posting on Plant Forum.
Please confirm OpenPlant Modeler version your are using.
Also, Please check by default value of below variable in Project PCF file.
OPM_REPAIR_JOINTS_ON_ATTACH=True
if it is set to true as above, then make it is false. Please verify same and update us.
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Answer Verified By: Rahul Kumar
THANK YOU! IT WORKED
