How to define Schedule list in Standard Preferences?
We would like the ability to filter our component selection with the Specification, Pipe Diameter, and also the Pipe Schedule.  We have managed to add the Schedule property to the standard preferences tool bar but the drop down list is not showing the list of schedules in our specifications.
We would like to be able to filter out STD, or Schedule 10, etc.
This is what the class editor looks like.
OPM version 08.11.09.568
Brynn Paluck
  • Hello Brynn,
    To filter item you could use Filter option provided in Spec Grid dialog. See image below.
    I Believe there is no customization needed here, if this is the only purpose you are looking for.
    HTH
    -Regards | Rahul Kumar
    Product Engineer - Bentley Systems
    Are you a CONNECTED User? Click here to find out more.
    Find out whats inside Connect Advisor Update 2. Click here
    Produce 3D models of existing conditions and Bring them to life!!
    Rahul Kumar
    Product Engineer – Global Technical Support | Community Moderator
    Answer Verified By: Abhilash Panchal
  • Hi Brynn,
    Standard Preference is related to Plant Associated items including Pipe and components. Schedule property is specific to Pipe only and if you see Flange or other piping component table in Spec you can find value as empty. Hence, only two drop values are visible.
    Alternatively, if you change Input Method as 'Keyin' in Schema and manually type schedule value as '40' or any value in Standard Preference, but this value should present in Spec. Then query will run successfully and same Schedule pipe will get placed. See below screenshot for reference.
    Please verify the case and update us the result.
    HTH
    Regards | Abhilash Panchal
    Abhilash Panchal
