We're trying create/use assemblies that have non intelligent graphics. For example, text elements. Creating the assemblies in not a problem but when inserting one is creating multiple copies (3) of all non intelligent graphics. In the picture below, text "CONCENTRATE" and material lines in blue are all inserted 3 times even if they exist only once in the assembly. Any idea how to get this right?
Best regards
Alain
Hello Alain,
In which version of OpenPlant PID you are facing this issue? Have you upgraded your workspace from any lower to higher version? While inserting assembly only text are showing three in count or tags as well as component also gets distorted?
Please raise a service ticket so that we can investigate more on this issue.
Regards | Deepak Singh
Hi Deepak,
Version is 08.11.10.631 as specified in the tags. Yes the workspace is customized for our needs and has been upraded from a lower version. All non intelligent graphics (texts, lines, etc.) are inserted three times.
Service ticket number is 7000766862.
Thanks for posting your query on plant forum,
Yes, we have found your service request number & investigating on the same. From here, we will proceed further with this issue through service request & will provide you regular updates on this issue.
Bentley's answer to this SR was
"We have already logged defect on this issue & Defect Report # 715506, and will be evaluated by the product management team for our regular SELECT updates."
