In the article it gives the dwg output as 2D only.
Since running OPIM version 08.11.11.285 with AutoPlant Modeler version 08.11.13.211 and update to .245 we have been getting a 3D dwg ouput as well as the 2D. Can this be turned off as we do not require it.
Best Regards
John
Hi John,
Thanks for posting on Plant Forum.
Please let me discuss this issue with AutoPlant Subject Matter Specialist and will update you accordingly.
HTH
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Please confirm the value assigned to below variable IE_OUTPUT_FORMAT=DWG in Style.cfg file present in your style folder.
If this variable value is not set to DWG then please try to generate isometric by keeping this variable and update us the result.
Also, Please refer below WIKI link.
Please test the case and update us result.
Answer Verified By: Vidit Ruhela
