Can OPPID work with SQL2016?
Hi Loukas,
Thanks for raising your query on Plant forum.
Please explain your requirement in detailed for using SQL 2016 with OPPID. Also, You need to look at the Read me File for your specific version of Plant Requisites.
Also, you can refer below WIKI link for Reference.
HTH,
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
