Hi Everyone,
We have a project that has modeled using the mixed metric workspace. They are requesting imperial dimensions on the isometric (instead of the delivered metric dimension definition)
Is this achievable?
Thanks!
Dave
Hi David,
Yes, this is possible. In style.cfg you'll find the following section:
#-----------------------------------------------------------------------------# Change the below values to 1 when the isometric should show diameter or# length values in a different unit#----------------------------------------------------------------------------- ConvertLengthUnit = 0 ConvertDiameterUnit = 0
Setting either one to 1 swaps the units. In your case this would need ConvertLengthUnit=1. This will also convert the units in the report.
Frank
Answer Verified By: David Stott
Thanks Frank!
Also below is the wiki article which you may find helpful.
How to Convert Dimension and Pipe Diameter in Different Unit for Isometrics BOM Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.11.224 (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings/Attributes Subarea: Dimension… Last edited over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
-Regards | Rahul KumarProduct Engineer - Bentley SystemsAre you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Rahul Kumar
Thanks Frank, worked perfectly :-)
