i need to create a macro to draw a rectangle by two point , the first point is : x = (max margin left of the sheet), y=(pick by mouse) and the second point is : x = (max margin right of the sheet), y=(pick by mouse).
do you have any idea ?
thank you
Marco
Hello Michele,
I believe this is a Generic query, and ideally it should correlates to MicroStation Platform. Please post your query to MicroStation Product forum at below mentioned link.
Also, you can find similar discussion on Macros under MicroStation Forum link.
HTH.
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Hi
I believe a similar discussion held on another forum thread.
HTH
-Regards | Rahul Kumar
Rahul Kumar
