Hi Everyone!
I have a project which would like to take advantage of the ability of posting isometrics to ProjectWise.
I recall seeing well detailed instructions on all the steps required to accomplish, but have lost the link and can't seem to find the info searching through the forums.
Does anyone know where I can get those steps?
Thanks for your help,
Dave
Hi David,
Thanks for Posting your query on Plant Forum.
I believe the Project you are referring to is a Managed Project, and currently you are getting no Buttons in Isometrics Manager to Post on ProjectWise. See image.
But, In my Knowledge If you are connected through Managed Workspace Post to ProjectWise option will get automatically highlighted. Correct me If I interpreted any wrong Information. Also, you could add more Info on this case.
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Hello Dave,
In addition to Abhilash query, you could also find below forum link where some discussion was held.
Openplant Isometric Manager Posting Isometric To ProjectWise Verified Answer HI , I tried to explain my questions. in below screen shot, Please reply for any solution, Regards, Vivek By Vivek Baraiya over 8 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Forum 4 replies Latest by Vivek Baraiya over 8 years ago
in case something does not work, we will meet on Monday to discuss the same. Also create Service request for this query in case a detail discussion would require.
HTH,
-Regards | Rahul Kumar
Rahul Kumar
Hi Rahul - thanks for the suggestion. I've logged an SR to more clearly describe and track the issue. 7000782725
I'm sure that a quick online session will pin point the faulty config and set us on the right path.
