APM V8i SS8 08.1.13.245
OPIM 08.11.11.285
AutoCAD 2016
When a stub in with reinforcement pad is inserted on a pipe, OPIM cannot process the line. See attached image:
I have already applied the solution found here:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/35359/to-report-the-reinforcing-pad-using-schema-customization-in-openplant-isometrics-manager
After applying these schema changes I still get the attached error. Please advise.
Jesse Wolfe
Hi Jesse,
Thanks for posting your query on Plant Forum.
The Wiki you refer is related to BOM of reinforcement pad.
You can follow below wiki to remove this addon error while generating Isometric.
HTH,
Regards | Abhilash Panchal
Regards, Abhilash Panchal Product Engineer - Bentley Systems
Are you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
So the solution on that wiki article is to log a service request..... thanks....
Hi Jessie,
This should work. Can you attach the intermediate file so I can investigate a bit?
Frank
Hi Frank, here you go.. I'll include schemas as well just in case you want a look
5861.1-100-G.intermediate.TXT
2134.schemas.zip
ADDON 6 is the trouble item in the intermediate file
The issue is that OPIM expect a repad as part of a branch connection on a pipe. Here the repad is on an elbow and thats currently not supported. So we need an enhancement for this one :(
please forget about that answer, need to think a bit more
