Modifying dimensions styles settings in the seed file for Isometrics
I'm trying to change our dimensions to have ticks rather than arrows as the arrows overlap and do not look good.  In the seed file, I go to: Element > Dimension Styles, and I update the settings accordingly but when I run a test iso nothing changes.   That is typical for any changes I make here.  It's like it's lost its link or there is an override in place?   However, If I modify settings through the "Isometric Configuration" dialog box these setting do take effect when I run a test iso.
